Hipster Bias Question
Started by guitarhands03, May 18, 2012, 12:43:00 AM
guitarhands03
Just finished up a Hipster baby board build and Im running BC 108's. I messed around a bit on the bias ranging from 3.5v-5.5v on the collector of Q2 and didnt care too much for the fuzz so I cranked it to 8.2v and really dug the sound. Will this do any damage to the transistor and is it ok to just bias to taste? Thanks!
The quick answer is probably not. The definitive answer is found in the datasheet.
guitarhands03
I feel like such a boob  ;D! looks like max voltage it can  handle at the collector is 20v if I read the datasheet correctly. Thanks for the reply!
