Tremulus Lune
Started by tenwatt, April 20, 2012, 02:19:49 PM
tenwatt
Does anyone have a link to add a "Ramp" switch on the Tremulus Lune?  Also, can I have a LED that flashes on a true bypass switch that is only on when the effect is on?  If so, how would I do that?  I will also be putting a rate doubler on a footswitch.  I want to put an LED indicator on that switch.  Would I just put the (-) of the LED on pin A1 of the switch and the (+) to 9V?
Not too bright....
Here ya go.
http://fuzzcentral.ssguitar.com/tremulus.php
But the Sym pot works better imo. The ramp is extreme with no resistors; the sym pot is sweet and swampy. :)
Edit: The 4ms board already flashes in time and is only on when the effect is on. To do the same thing on, say, the Commonsound board or layout, you should be able to just connect the ground of the rate LED to the switch instead of to the board -- this works on *almost every* LFO effect with a separate rate LED. But watch for ticking.
