Cave dweller in a 1590BB?
Started by djaaz, April 11, 2012, 11:03:18 PM
djaaz
Cave dweller builder:
I just redraw in eagle (mostly for exercise) the cave dweller using regular size components.
Is there a point to etch it to use in a 1590b box or better use the sea urchin?
I have an echo base, a sea urchin & i plan to build the 1590A cave dweller anyway...
I don't know for sure, but it sure seems like you have a lot of DIY Delay!
To make you feel better, I have built all of the ones I know of except the cave dweller at this point. I will at some point, but probably not till the double version is out...
djaaz
Yes. I don't know what happened to me...
Add to that a memory toy and a Dirtbag Deluxe.
I have a PT80 i bought from you and i just received two Dirtbag boards from Brian.
Welcome to the DIY delay club!  ;)
My favourite DIY delay is the one I build myself as a part of my lineup. It's similar to the Rebote/Sea Urchin, sort of a mix between them really. After that is the Dirtbag and Echo Base.
djaaz
A rebote. Here's one i don't know.
Looking at the schematics looks like they could almost be built on the same pcb. Is there so much difference between them?
That topic was a bad idea.
