My Echobase Delay (non-MB build)
Started by pryde, March 21, 2012, 09:56:09 PM
pryde
Here is my Echobase Delay build. Cool modulation options and tails switch. This pedal sounds really good. The PT2399 chip does impressive analog repeats for sure.
How did you do the tails with this Pryde?
Your pedals are very tidy, nice work
Quote from: nzCdog on March 23, 2012, 03:26:42 AM
The tails switch is part of the PCB in the board he used.
pryde
Quote from: midwayfair on March 23, 2012, 02:54:01 PM
True. Note that the pedal is not true bypass if you do the tails option though. You can wire it TB and lose the tails option if you want.
