Secure the pots washers without leaving marks in the varnish?
Started by add4, February 27, 2012, 11:12:47 AM
add4
Hey all ..
i scratch the varnish of my enclosures very often... do you have tips to avoid that?
i was going to try painters tape all around the nut but it's going to take a lot of time.
i'm already using a (english vocabulary missing) ratchet(?) to avoid scratching it, but i still see some scratches.
Any idea is welcome
TNblueshawk
I had used needle nose at one time which were great ....until they would slip. Right now I use a cescent wrench and I'm just EXTRA careful when I turn it to make sure the ends are not touching that enclosure.
You could make a reusable jig maybe with plastic or cardboard and just place it over the pot shaft. Or, just but knobs with big lips  ;)
John
badgerific
A socket wrench thing should do it without scratching the varnish. I've been meaning to get a set for a while now.
GermanCdn
For the jacks I use the Cruztools Jack/Pot tool, have yet to scratch an enclosure with it.  For pots, I use a socket set from Obi I picked up for three Euro.
If you use any type of wrenches or pliers, you will scratch the enclosure, because they have 90 degree corners and will slip no matteer what you try.
TNblueshawk
I probably have 75 or more sockets and not a sinlge one fits the nut on a pot, I mean WTF? I couldn't believe it when I tried them all  ::)
John
sgmezei
I magically got one set of sockets that is long enough to do pots. Does an amazing job. I have two other sets of sockets that are not long enough.
Do you have all imperial or all metric? It could be that your nut is of the opposite type from your sockets.
However, I have never had that kind of problem. I think my Alpha pots are all 1/4" nuts.
DutchMF
Come on guys, it's not that tough! just wrap a tissue around anything you want to tighten and take really,really good care! Just don't drink beer and try to assemble your pedal at the same time. The right tools for the right job will get it done anytime!
Paul
CRBMoA
I have a couple of flat, cheap wrenches that came with some furniture or something I assembled for a relative.
I'll post pics later. They are perfect.
TNblueshawk
Quote from: DutchMF on February 28, 2012, 07:57:49 PM
Paul
Does it work better to use that tissue before or after I blow my nose?   :)
John
thetrend77
DutchMF
Quote from: TNblueshawk on March 01, 2012, 04:49:39 PM
LOL! Preferably after, as it lessens the friction between enclosure, nut and washer..... But still before drinking the beer, that's still reserved for examining your work with a satisfied (and stupid....) grin on your face!  ;)
