Slambox Master Volume
Started by claytushaywood, February 18, 2012, 02:53:49 AM
claytushaywood
I wanna put a master volume on the slam box so I can get a bit more of the effect at lower volumes... with the madbean layout Can i just wired a 50kA pot as a variable resistor in place of the 47k resistor?
oldhousescott
Yes, that will work. You can add a bright cap across pins 2 and 3 of the pot if it gets too dull sounding when turned down.
