Sagan Delay Send/Return Jack Grounding?
Started by Jakes Dad, May 23, 2024, 06:27:21 PM
Jakes Dad
I'm finally getting close to finishing up Diablo Chris's Sagan Delay from the 2016 run - yeah, I'm a bit slow and don't work fast either. Initially I intended to ignore the Send and Return jacks but once I discovered the extra room in a 1590DD and read Chris's comment in the build doc about using them with an Electro-Harmonix Nano Stone phaser I changed my mind. The build doc has the line "GND - Courtesy ground. Can be connected to the input jack to ground all the jacks." Does that mean I can run one wire from there to the input jack ground and I'm done? That slow guy in my head seems to think I should do a daisy chain connecting Input, Output, Send, and Return grounds, but he's the reason I've been messing with this for so long.
Thanks,
Chuck
Yessir, once a jack is grounded to the enclosure, they're all grounded, assuming you're using metal jacks.
Jakes Dad
Cool. Thanks, I can get it done and still have wire left!
Chuck
Quote from: Jakes Dad on May 24, 2024, 01:45:19 AMCool. Thanks, I can get it done and still have wire left!
Chuck
Bwahahaha
