Aveces! - Tap Tempo version of the old STM tremolo
Started by culturejam, July 10, 2023, 07:17:32 PM
After much mucking around with the TAPLFO chip, I wanted to use it with the audio portion of my near-ancient Shoot The Moon tremolo (itself derived from the Tremulus Lune). I pared down the waveform options to just 4 (of 8 in the original code). Works and sounds great. I gave this one to my guitar teacher.
I laser cut/etched a face plate from 1/16" basswood ply and stained it. Then did some fine sanding to smooth it out and pull back the color a bit.
Side note: I named it "¡Aveces!" because "sometimes there is sound, and sometimes there is not". Apparently I'm the only one that thinks this is funny.  ;D
That looks fantastic, and that is hilarious.
Quote from: jimilee on July 10, 2023, 08:05:42 PM
Thanks!
I need to do another adjustment to the PCB and when I get those in hand I'll send you one (with a programmed chip).
Quote from: culturejam on July 10, 2023, 08:34:48 PM
Thanks!
That's very kind, thank you.
