Aqua puss board BBD conversion.
Started by LaceSensor, January 04, 2012, 04:38:27 PM
Hi all
I have got one of the old FSB Aqua Puss boards in a trade (a red one, I beleive the latest version).
OBviously its designed for the MN3005, but they are too hard to get.
Do you reckon I could succesfully make a daughter board, incorporating the jumpers seen on the madbean aquaboy, and then run this via jumpers to the IC socket on the board?
Or am i pipe dreaming?
Thanks for your insights
Ian
Swap Vdd & Gnd, Connect Vgg & Vdd.
Tie the output resistors to ground (that'd be R24 on the new boards).
Might have to cut some tracks I can't think straight right now and don't have the files for this exact board.
Sounds tricksy
When you have a clearer minute at your leisure of course and if you wouldnt mind checking it out thatd be grand. I have some diagrams of the FSB puss board..
thanks a mill
Quote from: LaceSensor on January 04, 2012, 10:33:59 PM
Sounds tricksy
thanks a mill
Chuck us a diagram then and i'll have a look, shouldn't be too tricky.
Im talking tosh all I have is pics of the PCB and a BOM, sorry.
Ill have a dig at FSB...
