Spaceman Effects Gemini III
Started by Hexjibber, August 17, 2019, 06:39:34 AM
Hexjibber
Here's my latest build, the Gemini III by Spaceman, built on Deadendfx 'Fuzzimile' board.
I'd like to say it was an easy build but I reality was one of those where nothing went quite to plan! Also lots of oddball components, to me at least, things like weirdly specific resistor values (21.5k?) and less common cap values. I stuck to the BOM though, as always if something is worth doing...
Tried my best to get transistors in the spec'd range and the voltages were as they should be so think it worked! Sounds great I have to say.
For anyone not familiar its a germanium and silicon fuzz with a blend pot to mix the two plus some switchable gain options. Loads of sounds in there so need to have a proper play with it.
The etch isn't my best so I roughed it up a bit with wire wool to try and give it a worn in look haha!
mcallisterra
That etch is awesome! I love the design, excellent work.
Sent from my BND-L24 using Tapatalk
Very nice!  You've got the 'distressed' look just right.
What are all the toggle switches controlling?  Is it all gain controls for the different transistors?
Hexjibber
Quote from: mcallisterra on August 17, 2019, 06:48:51 AM
Cheers!
Hexjibber
Quote from: mjg on August 17, 2019, 07:05:29 AM
The two lower ones are for the transistor sets so for example you can switch the germ to higher gain and the silicon to lower then blend to taste, it's a pretty cool idea. The upper toggle is for the germanium side only and changes the direction of the tone sweep, I haven't played around with this much yet though
Spaceman really do love their weird resistors (and other parts to be honest). If you ever look inside their pedals, it looks like someone just grabbed parts at random from a salvage bin, completely random assortment of wattages, brands, tolerances, etc.
Hexjibber
#6
Quote from: somnif on August 17, 2019, 07:34:17 AM
Indeed! I don't normally subscribe to mojo stuff of that sort but this time round I thought I'd go the whole hog! I loved the sound of the original in demo vids so thought I could do worse than stick to listed values etc. Nice to build something a bit different every now and then!
Have to say though, the workmanship inside their pedals is first class
Quote from: Hexjibber on August 17, 2019, 06:39:34 AM
I like the way this man thinks!
PMowdes2
Nicely done indeed
We've added a few new Spaceman boards recently 😉
DeadEndFX
great stuff. Good to see you back to building, keep them coming.  8)
Johnnytoobad
Hexjibber, any chance you could share your drill template?  Is it a 1590bbs?
Very cool!
Betty Wont
Ooooh that is magical!! I love the roughed up distressed look, very cool.
