Man o War Build
Started by in8241, August 14, 2022, 04:20:18 AM
in8241
Man o War, calibrated at a lil over 500ms and on the verge of oscillation. It has a 7815 wired between the jack and PCB, bolted to the inside for a heatsink. I run it off an 18V supply, down to 15V, then 12V on the board. Finished with some experimental hydro dipping that continues on the back. Cleaner sounding analog delay, I really like it.
Killin it with the hydrodips.  Nice work, I like that look, and perfect for the delays.
