Charge Pump for the BBRR (Or any roadrage board)
Started by DarfnageL, July 27, 2022, 02:14:23 PM
DarfnageL
I just got my BBRR and completely forgot to order the slide switch for use with different charge pumps. I ended up getting the LT1054 for its higher current capabilities and don't really plan on swapping it out for a different charge pump.
Outside of the *need* to switch were the LT1054 or other compatible configured charge pump to become unavailable, if my plan is to stick with the LT1054, I'm assuming the slide switch becomes unnecessary and the spot on the board can be left unpopulated. There is no need to jumper the switch spot, right?
