Harbinger 1.5 - Photocells in a post-2020 / post-SB world
Started by jessenator, March 18, 2022, 01:51:58 AM
jessenator
Greetings.
Having looked up and down what's been posted on the forum, I couldn't really come up with a source that sells the two recommended cells anymore and wanted to pick the collective brains about this.
I can't find the NSL-7532 for sale at all, and got to poking around for a spec sheet. However, not being an EE, I can't translate what's going on with this factory sheet vs what suppliers currently have available. So if the answer is there, I'd love some help in that dept.
If there's a turnkey p/n that folks use now, that would also be most welcome.
So here's the table from the Silonex datasheet (7532 highlighted):
And here's what's available (just as an example) from one source that popped up while searching the original p/n. I selected the physical width (I think), but perhaps not the lead spacing (pitch?). I didn't get far with the p/n from the alternative photocell that SB once sold.
Thanks for the help/direction!
"All you need is fuzz"   ~not Lennon
jessenator
Well, I've managed to find the hermetically sealed variant of the NSL-7532, the 7530 https://www.alliedelec.com/product/luna-optoelectronics/nsl-7530/70136804/
I guess, is this package version going to be sub-optimal in the HarbingerOneFive? In an older topic from 2015, there were other photocells referenced and a look back at the Wayback Machine page shows more numbers I can't find any listings of nowadays.
So if there's an operational reason to not go with that 7530 part, I think I'll go with the 9203 part, since I'll need it for my Glass Hole anyway.
