Power Supply Question
Started by skypn, October 16, 2021, 06:06:28 PM
skypn
Consider this schematic:
I have seen the same PS, but only R1 is placed after D1. Is there a difference?
TIA
Knowledge for Knowledge's Sake
skypn
And also, what type should C2 be? MLCC, or film?
Zerro
Order of R and D is not important. 100nF capacitors in power supplies are better ceramic, here for minimally 12V but better for 25V.
Quote from: Zerro on October 16, 2021, 07:10:34 PM
Ceramic, not metal film or even mlcc? Don't see to many people using ceramic values above 1000pf. For pedals anyway.
Quote from: skypn on October 16, 2021, 06:06:28 PM
TIA
While the order doesn't matter, I'm not sure why anything would be placed before the protection diode. Just a preference, I suppose. I will typically use metal film in the power section.
Zerro
#5
I use ceramic multilayer. The lowest ESR and ESL, tiny size, high current peak. Not so depending at temperatures. Class1 as so class2. It worths to invest to it.
