Dragonbeard Trim Pot
Started by HousTom, February 14, 2021, 07:59:19 AM
HousTom
That 9mm 1k B pot...
Is it this?  https://smallbear-electronics.mybigcommerce.com/alpha-single-gang-9mm-pc-mount/
Or this?  https://smallbear-electronics.mybigcommerce.com/alpha-single-gang-9mm-right-angle-pc-mount/
Cuz the build doc has a hyperlink to this (which I think is wrong).  https://smallbear-electronics.mybigcommerce.com/alpha-single-gang-9mm-pc-mount/
I'm pretty sure it's supposed to be this.  https://smallbear-electronics.mybigcommerce.com/alpha-single-gang-9mm-right-angle-pc-mount/
Anyone who's built it could answer.  It's either A) I'm dumb or B) the build-doc has a typo.  Thanks.
TGP39
Yea, that's confusing.  It's definitely a 9mm right angle pot.  Madbean listed it as 9mm plastic shaft pot so I think this is the correct pot;
http://smallbear-electronics.mybigcommerce.com/alpha-single-gang-9mm-right-angle-pc-mount-w-knurled-plastic-shaft/
HousTom
Thank you TGP39. I think you're right.
Yeah it should be the plastic shaft one. I put the wrong link in. Thanks for the heads up. I will correct it now.
