Can I power LED with DC Jack ?
Started by Jyka, January 02, 2021, 04:39:22 PM
Jyka
Hello :)
It's seem we need 9V to power a LED, but battery are expensive and I prefer DC Jack for long term economy
When a check a basic led circuit i found this http://pdfxevav.achatsenchine.fr/diagram/philips-led-circuit-diagram
So can i use a dc jack to power the led and the rest of the pedal ?
Regards
Jyka
Aentons
#1
You sure can. The resistor is needed in series on either side to limit the voltage current so the led doesn't burn out. Usually a 4.7k will be about right for the led. The rest of the pedal circuit is usually good on 9v
Jyka
