uproar "riot"
Started by gtangas, March 28, 2013, 01:19:51 AM
gtangas
hi
Finish my uproar!
I think it was the most complicated build i have built! Not due to build problems but for the modifications that I add to make!
Change the diodes until i get some different voices
Used the tone mod
Tried the presence but it was to subtle. so I tried the midrange boost and... nice!
I think that gives a extra 2 voices to this pedal!
Use some vinyl sticker (laser printed) from staples, spray clear coat and voila!
I like the uproar... lots of gain!
Some photos!
guts:
diodes:
Enclosure 125b (bought from tayda... very nice quality for the price)
not very happy with my wiring but working on improving it!  ;D
Thx
Sérgio
jprizz
Nice touch with your graphics, quite fitting. Don't worry about your wiring, it looks fine and only gets better as you build more. There I just gave you an excuse to build more!
Stomptown
#2
Quote from: jprizz on March 28, 2013, 02:25:45 AM
Great looking build! I love the name and matching graphics...
I would have to agree. If it works as expected I would leave it. I messed up a couple boards trying to redo the wiring and wish I would have left them alone. It's pretty hard to keep it clean without board mounted pots anyway...
Edit: In the future you may consider buying small zip ties to clean things up a bit. I love using them myself.  First I wire up all of my jacks (and battery snap) to the 3pdt inside the enclosure. Then I wire up my pots and all other wires to the pcb. If you make the input/output/ground/9V wires extra long you can zip tie them down the middle of the enclosure between the 1/4" jacks and cut them to size before soldering them to the 3pdt...
Man, those graphics are great! Nice work
Digging the graphics, and yeah, if it works, don't touch nothing. Make it up on the next one. I recently went back and did some resoldering on my first madbean build because it developed a problem, what a nightmare that was. Looked like I wired it with my eyes closed.
gtangas
This build I put the pots, the board, then hook up the power and led, the jacks with the wires already solder and then footswitch with the board Connections. It was more simple that way.
I make all the graphics with photoshop, the problem is to get right with the alignment hehhe
The guys from staples forgotten to take out the "fit to page" so when I arrive at home and match the size.... Hehehe OMG
Luckly there are so many projects to build lol...
Marv Mod
Nice use of the Paramore cover! Great work! And yeah, the wiring will improve over time, if it works, who cares?!
fish22
Really cool build!
Love the graphics!
Hi, my name is Wyatt.
gtangas
thx guys!
and again thx Brian to give us all these fine projects!
