Can someone check my block diagram (parallel mixer - JMK paralyzer content)
Started by LaceSensor, October 23, 2020, 09:28:24 AM
cool thanks very much for checking that for me
I beleive the RAT and lovetone big cheese are also in phase so hoping those will be fine :)
diablochris6
Hey Guys
So I finished this build, and its actually amazing.
On testing I have figured out the following options with the Paralyzer from JMK:
Send one goes to a Rubadub Reverb into a RAT, which you can turn them off independently with their own switches.
The other send goes to a Big Cheese, again on a toggle switch.
Both paths are them "summed" at the output jack.
1 - Reverb.
2 - Reverb into RAT.
3 - Reverb into RAT with clean blend (Cheese toggle off).
4 - RAT only
5 - RAT with clean blend (Cheese toggle off)
6 - Big Cheese only
7 - Big Cheese with clean blend (RAT and Reverb toggles off)
8 - RAT and Big Cheese in parallel
9 - Reverb into RAT with Big Cheese in parallel
10 - Reverb with Big Cheese in parallel
11 - Reverb with clean blend (bear in mind the Reverb knob itself is a type of clean blend)
12 - Clean with clean blend 🙂 🙂 AKA the pedal does nothing sound
Thanks for all the advice and comments, it helped with pulling this off.
