Handy little tool
Started by madbean, October 18, 2020, 05:49:47 PM
If you need to get a bunch of voltages from inside a pedal, a ground clip wired to a the sleeve of an empty plug sure does make life easier. Not sure why it took me so long to get around to making one.
Nice, I see what's going on there.
That's in the bucket of "why didn't I think of that very obvious thing?" Nice.
peterc
Affiliation: bizzaraudio.com
Muadzin
I am not quite sure what this is supposed to do, I guess I am not as savvy as I would like to think. Can anyone enlighten me?
Quote from: Muadzin on October 19, 2020, 10:03:40 AM
If the Sleeve of the jack is grounded (to the enclosure or directly with a ground wire) then once this is plugged in, it has a constant connection to GND. No need to hold your black meter lead to GND or poking around to find it  ;)
Oh man, I've never thought of that! That's so smrt.
I was at a loss as well, i've had mini-grabber leads forever and use one of those to free up a hand.
Quote from: davent on October 19, 2020, 05:10:08 PM
Minigrabbers are what I use as well.
Spare alligator leads, here.
Quote from: alanp on October 19, 2020, 11:01:52 PM
I also have banana plugs to alligator clips lead but the mini-grabbers are much easier to use, can get into much tighter and further away places.
https://www.madbeanpedals.com/forum/index.php?topic=30928.msg306810#msg306810
