Enclosure Size - Fat Pants
Started by Hack_Black, November 22, 2011, 08:30:00 AM
Hack_Black
My first post - looks like a great place.
I ordered some boards, but at this time I'm only going to build the Fat Pants. I've built pedals, but never shopped my own parts.
What size enclosure should I get for the Fat Pants? I'd rather not have a tight fit, and I'd rather get it pre-drilled. The PDF directions don't specify which box (unless I'm missing it).
I think I can handle the rest of the parts.
Any help appreciated. Thanks
If its your first build I would go for a 1590B or a 125B.
Personally I think a 1590B is a pretty nice size for one/two knob pedal.
A 125B will give you a lot more room to work with though.
If you are in the US there are loads of places that do pre-drilled enclosures (General Guitar Gadgets, Pedal Parts Plus, Mammoth Electronics etc.). In the EU there are a couple (Musikding, Banzai Music).
Good luck with the build mate!
Hack_Black
Quote from: raulduke on November 22, 2011, 09:47:46 AM
Thanks! I ordered a 125B, but now I'm thinking I should have gotten the 1590. Oh well, all the parts are ordered. Can't wait to check this thing out.
I much prefer 125Bs. They will be fine.
Hack_Black
I just populated my PC board. I should have asked this earlier, but how are you guys fastening/supporting the PC board in the enclosure?
I had always used the plastic standoffs, but there's no holes for them and I see you guys don't ususally use them? How do you attach the board to the enclosure?
I generally mount the to the PCBs. Double sided sticky foam is your friend.
Hack_Black
I guess that's what I need (sticky foam).
I bought a socket for the charge pump IC, but I didn't use it. I just soldered the IC in. Any reason to socket the IC?
Thanks.
add4
reasons i'm aware of:
easier to try different IC
easier to change it if by accident you soldered the IC in the wrong place or backwards
main reason: you are certain you won't fry your IC while soldering it
Quote from: Hack_Black on December 05, 2011, 11:25:52 PM
Thanks.
Hack_Black
It's done. Thanks for the help.
It's definitely a keeper. From videos, I kind of had a hard time hearing what it does. But what it does for me is makes my tone brighter without any kind of shrillness or ice pick, just more clarity. I love it. The Fat knob gives it more volume and a fatter tone, but it isn't mid-rangey.
I only played it through an amp set clean by itself and then in front of an Ibanez digital delay. It definitely is a big improvement on the tone, and makes the dealy sound killer.
Geosh
Anyone have it in a small enclosure and have some pics? Wondering how tight I can get mine...
bigmufffuzzwizz
If I can ever find a good source for 9mm pots I'm gonna put my Fat Pants in a 1590a!
Hack_Black
