Bumblebee Q4 Emitter voltage
Started by Chrisx5x5, May 30, 2020, 08:18:10 PM
Chrisx5x5
I am getting good signal and gain throughout, but no swell effect. Checking the voltages everything is OK except for the 3904 in the lower right of the voltage chart; I believe that's Q4. There I get a reading of 5.9V at the emitter instead of zero.
I've socketed that location and swapped out the transistor; no change.
I don't understand that part of the circuit well enough to know what to try next.  Can someone please help?
Thanks,
Chris
There's a post somewhere that's says that's right, the zero was a mistake.
Quote from: jimilee on May 30, 2020, 09:17:04 PM
I guess I should have pointed out that the 5457 hfe definitely has to be around 1.7. I'm still troubleshooting mine.
Chrisx5x5
