Ping Reverb planning
Started by isoceles, May 27, 2020, 05:23:31 PM
isoceles
I'm working on a couple of Ping Reverb builds - or I should say that I'm planning to work on a couple. The right-angle 9mm 100kB dual-gang pots seem a little hard to get right now what with Small Bear being temporarily closed. I was thinking about just trying 16mm pots and putting the whole thing into maybe a 125B so that the 16mm pots will fit. But I'm not sure what problems I will run into trying to do this. Anytime I have tried to deviate from the build doc on a project I have run into trouble. Because of that, I try to stay as true to the build doc as possible usually. And besides artwork, getting things to fit properly into an enclosure is one of the things I am worst at. What problems do you think I will run into here? Or - is there another place I can get the *same style* dual-gang 9mm right-angled 100kB pots as the build doc that I'm not seeing? Mouser is the web equivalent of a large chain warehouse store.  :)
Depending on your wiring skills, you won't have any difference. the only difference in the two pots is the size.
isoceles
Many thanks! I have several 1590B enclosures, but I feel like that might be going a little too small. I may give the 1590B a try anyway!
