Double Delay Boards
Started by phil esposito, September 02, 2011, 05:13:08 PM
Quote from: madbean on November 26, 2011, 02:58:18 AM
Built the prototype today. It's about 90% there. I'm going to tweak the compander a bit and the modulation.
Scruff-you were right about the little extra gain stage I put between the two BBDs. It is not needed.
Can I possibly see your schematic? If you have an OpAmp/Half One spare, I think I may be able to make some use of it...
Plus I can hopefully help with your compander and modulation.
I think as we have the DMM, we may as well make this the most bad ass alternative possible, Analog delay with tails is already most of the way there.
Just had a nice little idea here if you are loosing an Op-Amp, add a charge pump/15v reg and we could use theseee... http://www.smallbearelec.com/Detail.bok?no=247
Or ya know... when it comes about people could just use those and a Road Rage, just thought it'd be a nice use for them as the Aqua Boy only had 300ms originally any way and it's always nice to support a supplier.
