Info on the next batch of projects.
Started by madbean, December 13, 2011, 11:28:53 PM
ToasterMe
Quote from: jkokura on January 03, 2012, 09:24:53 PM
I know you can add one without too much trouble. So if you really want one that's a doable mod.
It's a different kind of Muff though, the Op Amp type, so maybe that's why Brian left it off.
Yeah it doesn't look too hard to do, I was just wondering if maybe Brian left it off because it sounded awful or something.
Quote from: Scruffie on January 03, 2012, 09:36:18 PM
Some people just like a switch, some people might not like the mod etc.
I'm not too keen on having the Ruetz mod on the Rat boards personally, i'd rather it was a 3 knobber.
Plus this has a Tone Bypass (you can see the pads) so it would make two controls redundant.
Yeah it was interesting to see the Tone Wicker mod get included. From what I've seen the Op Amp muffs were always 'bigger' and louder than the standard Muffs, so a switch that makes it 'bigger'-er and louder-er sounds like fun.  ;D
I opted for the tone stack bypass instead of a mid control on this one. It will be a true hard-bypass, too....it takes the tone circuit completely out of the circuit to prevent any possibility of loading down the output.
