Most challenging pedal builds
Started by slowpogo, July 24, 2019, 02:50:00 AM
diablochris6
Any time I try to put a circuit into an enclosure, it becomes the most challenging build to date.
Quote from: Invertiguy on July 31, 2019, 01:19:52 AM
To join the choir here, so far the Aion L5 preamp was by far the most difficult build I've attempted to date, although the Dimension C was also fairly challenging, although not horrible if you're using a slightly bigger box. Lots of Dead End FX stuff fits the bill as well, I'm slowly putting together their Enigma flanger (Lovetone Flange With No Name) and I'm kinda dreading boxing it all up due to all the off-board wiring.
Just as a heads up. A lot of the wiring going to the jacks on that build are actually grounds to the sleeves (not ALL but... quite a few) and you can save some time and wire by buss barring the grounds appropriately. That is what I did and I believe it saves about 6-8 wires.
