Aion Blueshift - DC-2 Dimension C - Depth
Started by destro, June 02, 2019, 08:20:53 PM
destro
So I have built two of these suckers (I like building doubles to compare and troubleshoot) and one sounds deeper than the other. I think the one that sounds deeper, could be a smidge louder which might enhance that effect. Lacesensor pointed out r9 being a resistor that can be adjusted for volume, but I was wondering what may effect the overall depth. The one I like sounds dimensional, the other one chorusy and could use a bit more warble. I've attached link for build doc.
https://www.dropbox.com/s/dl/51akvy8n0qy07g8/aion-blueshift-dimension-c-chorus-documentation.pdf
destro
So after looking at a few different schematics, I found one that labeled the switches between ic5b and ic7b as depth and switches between ic7b and ic7a as speed.
https://www.diystompboxes.com/smfforum/index.php?topic=72631.0
When calculating out the parallel resistor combinations for depth, not switched is 22k, switch 2 is the same, switch 3 would be 21.01k and switch 4 20k and switches 2,3 and 4 would be 19.18k. Not a big difference between 22k and 19.18k so I am Gonna compare resistance at r38 between the 2 and see if there is a difference. For speed there appears to be two options, unswitched 330k, switch 2 no change, switch 3 65.6k switch 4 no change.
