Total Recall Calibration Question
Started by Masochist, May 24, 2019, 02:31:57 AM
Masochist
Just had a 2nd attempt at calibrating my Total Recall by ear with Audio Probe as per documentation instructions and I think I've got it this time. Just wanted to clarify something.. the first time I tried I followed the instructions exactly but I had trouble setting the Gain2 trimpot right at the end, matching pin7 of IC7 with pin1 of IC4. However, I had a browse through the forums here on the subject and found someone had posted that there was a mistake in the documentation and really you should be matching pin7 with pins 14/15 of IC2 (NE570)? Doing it this way I got much closer to matching volume levels and if this is correct could we possibly get the documentation updated? If someone could confirm this is correct I'd really appreciate it!
It's correct! Straight from the factory set up document.
