Submini pinout
Started by DLW, January 03, 2019, 02:30:14 PM
DLW
How do you determine the pinout for a submini tube when all the wires are equidistant from one another? Is there a simple breadboard circuit I could build or do I have to peer into the glass and try to make sense of the various connections?
Tube is a 6N17B-V. This is where I bought it (listing contains diagram too)... https://www.ebay.com/itm/4x-6N17B-V-Miniature-Double-Triode-Tube-MELZ-Russian-SAME-DATE-05-1968-NEW/202459277971?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
zombie_rock123
Theres a little line on the bottom indicating pin 1 and 8 usually. Its quite hard to see between the wires
TFZ
Measure with the multimeter which two pins are the heater.
DLW
Quote from: zombie_rock123 on January 03, 2019, 04:47:08 PM
Sadly, these particular tubes do not have any kind of marking that I am able to see (even with a magnifying glass).
DLW
Quote from: TFZ on January 03, 2019, 10:04:43 PM
Could you please elaborate? I assume you mean I should apply power to one of the wires and check voltage on another? If so, how should I determine which wire to apply voltage? Also, is there a simple breadboard circuit I could use to do this?
DLW
I'm hoping someone could help design a test circuit for 6N17B tubes like the one Brian did for 6111 tubes... http://www.madbeanpedals.com/forum/index.php?topic=28539.0
thomasha
With your multimeter in diode/continuity check mode test equally spaced/opposite pins until you hear the beep. After you found the filament pins you just need to know the correct pin order (datasheet).
The pins are not symmetric, as the 6111, but follow a circular order. This way you can rotate the tube 180 degrees and the pins are still in the same position.
You can use the same circuit used by Brian, just use the correct pin order and reduce the resistor in series with the filament. The 6111 has a 300mA filament, while the 6N17B requires 400mA.
DLW
