2013 Harbinger One
Started by peAk, January 04, 2019, 03:59:19 PM
So I have had this 2013 version board sitting around for a while and finally want to build it. I noticed that the design was updated in 2015.
I reviewed the change log and didn't see anything that really matters much to me besides the modification of the slow speed R55 being changed from a 22k to a 1M. Is this mod possible with the 2013 board?
And all this being said, is the 2013 version board still worth being built? I don't want to spend time building this older version if the new version is a better in any way other than size.
Brian?
Comparing the two schematics, it looks like the 2015 version uses an entirely different setup for its rate LED than the 2013 version, so the R55 mod would have no equivalent on the older board.
Rockhorst
I've built both and they work equally well. So don't let that 2013 board go to waste, I'd say.
