Strange amperage reading on my power supply -.001
Started by blearyeyes, February 03, 2018, 02:05:17 AM
blearyeyes
When powering a circuit I usually see the amperage at a normal draw say for a distortion it might be .005 or 5ma. But while powering my Ultrastoner build it shows up @ -.001 or -1ma.
I'm trying to diagnose why the Ultrastoner doesn't sound right.. maybe DC leaking into the ground plane?
Can anyone give me a reason this might be?
Total shot in the dark... too big a resistor in series with the power supply?
blearyeyes
Well it's a cheap $50 linear power supply, I figured after 10 9v batteries it pays for itself. I just put a (pinhical) clone on it and it is reading -002 so I'll just have to chalk it up to another unanswered question of the universe.
Well, lets see. The 9V rail juices 4 transistors and an LED. Depending on the version you went with, each tranny pulls between 0.4 and 0.9 milamps. So a total current draw of 2mA is.... not outside the realm of possibility.
As for why its negative.... cheap DMM or leads plugged in the wrong sockets? Dunno.
blearyeyes
#4
Quote from: somnif on February 03, 2018, 09:35:41 PM
It's showing up on my linear power supply that I use on my
"bench”which is of course a folding table. I'm suspecting my cavalier grounding practices. BUT I'll check if I reversed the leads.
Dumber things have happened here....
Nope red is red and black is black.
reddesert
Sometimes at the limit of precision/accuracy of a meter, you get funny or unreliable readings.  I can get readings of a few millivolts by waving my DMM probes around in the air, due to induced currents, CFLs, or the Ghost of Pedals Past floating around the room - who knows? If your current draw is below a couple of mA, maybe the minus sign is insignificant. I would follow the usual debugging advice for the project (voltages, check continuity, audio probe the signal path, etc).
blearyeyes
#6
Yea, it's the amperage readout on my cheap power supply.
My cheap meter acts the same as yours.
I guess the operative word is "Cheap"
