PicKit2 Help
Started by kinski, February 15, 2018, 04:55:08 PM
kinski
Okay, i have the molecular compactor built and ready to go. But I can't seem to successfully get any code into it. I'm using MPLAB IPE to try and get the hex files onto the chips but nothing happens. I select the hex file, but the pickit2 doesn't seem to do anything, although the software says "Hex file loaded successfully." However, it says that even if I run the software without the pickit2 even plugged in. Could someone here please help? I must be doing something wrong.
kinski
Got it working!
Had to use a different program. Sounds great now. Kind of ridiculous how much you can do with this thing.
