Famowood/Envirotex - How Much Do You Use?
Started by BrianS, January 17, 2018, 09:05:06 PM
BrianS
I am finally going to give this a shot.  I've got the kit, read through several of the tutorials and threads but just wanted to get a little more info.  I went to the Envirotex calculator and sized out a 1590bb and it came out to 1.28 ounces to do a 1/16" pour.
Is 1/16" coat thick enough or do you need more?
Does the 1.28oz sound correct?  The sides were included in the calculation but I'm only doing the top. I've read that you want to make sure you mix enough the first time.
Any suggestions/advice will be much appreciated.  Thanks.
It doesn't take a lot. Put on what doesn't look like near enough and spread it around with something. I use dixie cups and only fill the bottom.
