Opto-Fet switch
Started by helos, September 17, 2017, 03:05:04 PM
helos
Hello,
I've read somewhere in DIY stompbox forum that opto-fet (like the one used in the Opto Tron switch) could produce distortion when the applied signal exceeds 100mV. Is this real?
So let's say that I have a pedal built with an optical switching system, would it produce distortion if I put an overdrive pedal in front of it? Putting a OD pedal would probabily make the signal greater than 100mV, thus a optical switch would distort...  :-\
BTW, what can you say about the 4N35? Is this a good alternative to the H11F1?
I've used the optotron and the Lumen many times. I have to admit that I haven't put an OD in front of it but I've certainly put fuzzes and all kinds of stuff with no distortion.
helos
Quote from: flanagan0718 on September 17, 2017, 11:50:17 PM
Ah ok... that reassures me a little  ::)
What's the Lumen? I've never heard about it...
WormBoy
Quote from: helos on September 18, 2017, 07:03:19 AM
A specific PCB for opto-fet switching that is/was offered by Grind Customs FX: http://www.grindcustomsfx.com/product/gcfx-lumen/.
