Twin Peaks Tremolo troubleshooting help please
Started by AntKnee, April 05, 2017, 05:08:35 PM
AntKnee
Tapflo pin 5 gets 0v - 7.6v
LM358 pin 1= 1.34v - 5.43v
pin 7= 1.05v - 5.42v
I'll desolder the LDRs and measure the resistance later this evening.
David, thanks again for helping!
drolo
these all look good (except pin 5 of the taplfo which should never get higher than 5V but I guess it's a typo)
AntKnee
Quote from: drolo on April 07, 2017, 08:21:35 PM
I don't think its a typo. I better recheck values in the morning.
AntKnee
Definitely not a typo. I have 7.6v on pin 5 of tapflo.
I desoldered the LDR side of the optocouplers and checked resistance. I have to set the rate very slow to get a steady reading. I am measuring 20 megaohm max on #1, and 10 megaohm max on #2.
drolo
but does the LDR resistance get lower with the change of the LFO voltage ?
AntKnee
The LDR resistance goes alternates from 0 to the measured resistance in sync with my tap LED.
I just swapped out LM358 for a new one, and I now have 4.8v on pin 5 of tapflo, which also alternates from 0 to 4.8 with the tap LED.
AntKnee
I missed this on my first check: R47 and R48 are supposed to be 100 ohm, I have 100k ohm. Correcting that now.
AntKnee
Resistance at LDRs is now at 400k on #1, and 200k on #2.
AntKnee
#38
After swapping R47 and R48 for the correct values, I am up and running.
I wish I would have noticed the resistor value when I checked all my components earlier. I'm not sure at this point if I also had a bad LM358 earlier, but I left my replacement in.
David, thank you for all your help throughout this troubleshooting. I greatly appreciate your help.
drolo
AntKnee
