Phase 45
Started by darrenw6000, January 12, 2017, 10:02:56 PM
darrenw6000
ive come across 2x 2N5457's they were labelled .40v so I assume I matched them at some point but never did anything with them, would they work for a p45 project.
Generally the answer would be yes. It is very easy to use a breadboard and verify they're a matched pair.
JackSkellington
I built a Phase 45 on veroboard and I tried two random J201s, I had just those, I adjusted the trimmer and the phase effect worked fine.
darrenw6000
I have now tried them in a glacticon(stomptown) build and they work fine
Willybomb
I used a couple of random 5484s a couple of times in smoothie builds and they've been fine.
