Take Pity On Me
Started by Flock of Bees, June 06, 2016, 03:25:08 AM
Flock of Bees
Hello everyone,
I've successfully built 2 pedals. One was point to point, the other, well, it was pretty ugly. I am currently working on the the 1590G pedals from this site. I've spent hours trying to trouble shoot what I'm doing wrong. I am currently building the  Mimik pedal. I've checked all my solders on the PCB and everything looks clear. I have finished the off board wiring, but I still am not getting any sound through the pedal. Does anyone have a wiring diagram/ or gut shots that I can compare my work to?  Thank you so much in advance.
-Flock of Bees
Post some pics of your build-up along with any voltages, in the tech help section of the forum.
there are tutorials on external wiring and 1550G projects from the bean himself here:
http://www.madbeanpedals.com/tutorials/index.html
if you don't find the culprit from there, do as matmosphere suggested and please open a tech help thread following the guidelines for getting tech help. good luck
Muadzin
I could use some pity too. I was building the DigDug 2 and had finished the board, about to drop it for the first time to see if it fits when I noticed that all the 8 2K pots were actually 100K's. So not only had I ordered the wrong pots, I soldered them in without checking. D'OH!!!
............................................________
..............?.....__.........................................:`.........../
............./__.(....."~-,_..............................,:`........../
.........../(_...."~,_........"~,_....................,:`........_/
..........{.._$;_......"=,_......."-,_.......,.-~-,},.~";/....}
...........((.....*~_......."=-._......";,,./`..../"............../
...,,,___.`~,......"~.,....................`.....}............../
............(....`=-,,.......`........................(......;_,,-"
.............`~.*-,.....................................|,./.....,__
,,_..........}.>-._...................................|..............`=~-,
.....`=~-,__......`,.................................
................................`:,,...........................`..............__
........................................_..........._,-%.......`
EBRAddict
In-focus, close up pictures will help. Nobody can diagnose your build issue from a paragraph of text. Also list out the other things you've tried (no sound with footswitch on or off?), chip voltages, type of power supply, etc.
Droogie
Quote from: Muadzin on June 06, 2016, 08:55:11 AM
If it makes you feel better, I swapped the Step and SubD switches. I was sweating bullets but I managed to desolder them without wrecking the board! It's a PITA but you can do it!
Muadzin
Quote from: Droogie on June 06, 2016, 05:05:46 PM
Desoldering turned out to the kind of fun that wasn't, but it was doable. The real PITA is in ordering 8 new 2K plastic shaft pots. Which means I probably have to wait until my next Tayda order. Which means waiting for their next code.
Flock of Bees
UPDATE: I went through and inspected the wiring for the 3pdt and some connections on the PCB. Everything is working fine now.
