Creating new pot values......
Started by Drew Hallenbeck, October 11, 2016, 07:44:51 PM
Drew Hallenbeck
So I've been thinking it would be easier to order a whole bunch of just a few values of pots then add resistors to come up with new values. This way, if I want to build something that calls for an odd value pot, I don't have to place an order and wait for a single item.
Here's something I've seen referenced here before. There are options for calculating new values for linear and tapered pots:
http://www.diystompboxes.com/analogalchemy/emh/emh.html
My question is, would this be a good idea or can anyone point out specific reasons/situations where this would be a bad idea?
Sure would be nice to just keep 2 or 3 values each for A, B and C pots then just make whatever value is called for......
Building with my daughter and occasionally selling as "Daddy Daughter Pedal Works"
Not for any real profit, just trying to have a self-funding hobby.
When you do that, sometimes (often) it will change the taper of the pot in a non-good way. For example, you may end up with most of the "play" all bunched up into the first or last 1/4-turn of the wiper. Other times, it doesn't seem to make much difference. It's mostly application-dependent.
Drew Hallenbeck
Even when adding different value resistors between 1&2 and then 2&3 like the calculation suggests for "A" pots?
stecykmi
Quote from: desmondtencents on October 11, 2016, 07:48:10 PM
ya it will always affect the taper somewhat.
basically if the added resistors are too small compared to the pot, it will affect the taper "too much". so you can do this but you can only change the value by an order of magnitude at the most before the pot no longer behaves nicely.
most people don't use this on log-taper pots either presumably because it alters the taper.
