New Hammond Enclosure / VFE Pedals Kickstarter
Started by playpunk, September 08, 2016, 01:40:09 PM
Quote from: Muadzin on September 08, 2016, 06:04:06 PM
There seem to be a lot of people here with exceptionally wide feet. Which if you think about it, what is the point of using a small box for a small footprint if you're not going to take advantage from it? Might as well use a big huge ass EHX/DBA style box instead.
Anyway, good for VFE. We hunger for more pedals with top mounted jacks. Slowly but surely its dawning on the makers that pedals with top mounts really are more pedal board efficient.
I have wide feet, but the 1590b footprint is fine as long as the pedals are an inch and a half apart or so. Given the option of probably only use 1590b but there are some pedals that Need larger enclosures.
mmlee
Got around to reading through everything. I see it's a few mm shorter than the bs, looks nice!
Would definitely make top mounts easier, I squeeze them into the normal 1590B Eddystone equivalents atm.
Marcus
>Marcus
