Mangler - Removing volume pot
Started by cresconio, September 10, 2016, 09:13:33 AM
cresconio
Hi there,
Recently build the mangler and I'm really digging it, although I'd like it to be a 1-knob pedal.
I'm not sure how to bypass the volume pot. Any thoughts on that?
Kind regards,
Cresconio
just jumper pads 3 and 2 of the pot pads and leave pin 1. That would give you maximum output all the time, which might be too loud. You can also put a resistor instead of the jumper, but you'd have to experiment to find the right value for your taste.
I would suggest to put an internal trim pot instead, so you can adjust it to a level you like and set and forget. You'll have to bend the legs and maybe add a bit of wire to fit it.
cresconio
Great thanks, gonna experiment with that trimpot indeed.
you're welcome. Just make sure to use a 500k trimpot too.
