pigbutt not working, can someone please help troubleshoot
Started by Obie bong kanobie, August 29, 2016, 05:37:03 PM
Obie bong kanobie
ok so i was checking over my voltages and they go as follows
IC1
1-4.42
2-4.46
3-4.28
4-0
5-4.52
6-4.52
7-4.55
8-9.41
IC2
1-0
2-5.07
3-5.02
4-0
5-0
6-5.04
7-9.42
8-0
ill post a picture as well
Obie bong kanobie
The only sub made was the 1.2k resistor. I had to use two 2.4k resistors in parallel
Your voltages look ok compared to the ones in the build doc. Are you getting any sound at all? Bypassed?
What does it do or not do exactly?
Obie bong kanobie
ok im taking the bypass wiring off and ill test it with just the inputjacks and dc jack  ill let you guys know what happens. its probably the bypass wiring, should have tested it that way in the first place!
