New Ver. Slow Loris Clip Switch
Started by Zerstorte Zelle, August 08, 2014, 07:26:56 PM
Zerstorte Zelle
I was wondering if I used an On / Off / On switch for clipping on the new version slow loris if I will still retain the functionality of the previous versions. "Center off"
-ZZ
RobA
Looking at the new schematic, an on/off/on should still take all clipping diodes out of the circuit when it is in the center position. Looking at the layout makes me think that this is still the case too.
murdog47
Yep...same thing just not board mounted anymore
cajone5
#4
Planning to wire up the switch on my slow loris tonight.  Wondering if I should use a on/off/on instead of on/on.  Can anyone verify that the on/off/on would offer a third no-diode option with the current board?
Wouldn't it have to be on / on / on?
cajone5
Ended up just using SPDT on/on.  Sounds sweet as is.
