Proco Reissue Rat DPDT to 3PDT with LED
Started by knd, August 04, 2011, 04:39:30 PM
knd
Hi All,
I was wondering if any of you know how the original DPDT was wired?  I am installing a 3PDT switch to add an LED.
Thanks
k.rock!
Have you unsoldered everything already?
If not, just flip over the enclosure, unsolder one wire and solder to the same location on the 3PDT. Remember the 3PDT is exactly as the DPDT but with an added "column" which you will use to add the LED.
-Kaleb
God bless!
www.kalebromero.com
mgwhit
Here's an article on RAT bypass switch wiring at Jack Orman's site: http://www.muzique.com/lab/true_bypass.htm.
