Chunk Chunk voltages
Started by Jazzman, July 30, 2011, 05:16:19 AM
Jazzman
Hey all, yet another question... After posting some questions in another section regarding the overall background noise of the Chunk Chunk build it has come to my attention that some of this can be removed by turning back the trimmers. I guess it has to be done by ear, but I should probably ask what are the minimum voltage readings on the jfet drains that I can get away with? Anybody tried this method? Did you take readings? Thanks to everybody who's helped me!
stecykmi
best way is to experiment, it will vary from build to build. I would try 4.25 volts on the first gain stage and see if that helps.
