W****er triple wreck clone?
Started by jimilee, June 12, 2016, 04:18:38 PM
Anyone have a clone of the full circuit? Looks like the t-wrex circuit is on hiatus.
zombie_rock123
Theres a bean layout in the members projects section I think, and Fuzzdog has a board for one
Isn't the Upper Decker a Triple Wreck clone? There is an etchable version in the discontinued PCBs section. I've built a couple before I recommend shielded wire for it, just an FYI.
Martan
Quote from: flanagan0718 on June 12, 2016, 06:07:49 PM
Yep. You can buy from Haberdasher, too.
blearyeyes
Jimi,
I think I have a T-Wrex if you had your heart set on through hole pcb.
Quote from: blearyeyes on June 12, 2016, 06:57:01 PM
Jimi,
I just didn't want to do it on vero.
blearyeyes
Habadashers are beautiful if you want to for etched.
Quote from: blearyeyes on June 12, 2016, 07:06:06 PM
Right, is the upper decker the full circuit? I've inly seen pictures with one stomp.
Haberdasher
Quote from: jimilee on June 12, 2016, 07:10:43 PM
Yeah it has the boost built in as well, so 2x stomps if you want.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Muadzin
Pedalparts.co.uk has a good layout. Also with the option to build it with the SHO instead of the shitty standard boost as in the original.
http://shop.pedalparts.co.uk/Wrecktifier_-_Main_PCB_+_Daughterboard_Set/p847124_12489328.aspx
Quote from: Muadzin on June 13, 2016, 10:00:18 AM
ordered
