DIY Reverb: Hold function?
Started by brand0nized, September 07, 2013, 04:58:16 PM
brand0nized
Is there a way to mod a DIY reverb, such as the Rub-a-Dub reverb, to have a hold function like this one?
kothoma
#1
The Zcat Hold Reverb is a digital pedal, most likely based on a Spin Semi FV-1 like several others of their pedals.
See also http://www.freestompboxes.org/viewtopic.php?f=1&t=14062
The hold function has nothing to do with the reverb effect per se, and you can see they also have a Hold Delay, so it's only a matter of the right firmware.
I can't see how to add anything like this around a Belton brick, for example.
But sometimes I wonder if it would be possible to create a EHX Freeze workalike with a PT2399.
Basically you would need a delay and a litte circuit to sync the input level/envelope and the feedback level/envelope.
