Good source for wire, preferably PTFE or similar.
Started by jball85, April 24, 2016, 07:27:50 PM
jball85
I'm looking for a good economical source of shielded copper wire with a Teflon or other type of jacket that can take solder heat with out melting or shrinking back ( without leaving exposed wire after soldering a connection to a board, pots, etc). Non shielded wire is fine too I'm in the market for both. 20-24 AWG (22 AWG preferred).
Does anyone know of a great source to get this wire or something similar by the foot, rather than buying an entire spool at a time?
Apex Jr, has loads of PTFE & i believe that includes shielded. Web site scratches the surface need to phone and confim.
http://www.apexjr.com/wire.html
I bought shielded from this guy on ebay.
http://stores.ebay.com/Johns-Silver-Plated-PTFE-Wire-Shop/Shielded-Wire-Coax-/_i.html?_fsub=3966787&_sid=155009&_trksid=p4634.c0.m322
jball85
Yeah it's looking like Ebay might be the best choice at the moment. Usually I would hunt this stuff down myself. However, unlike other pedal/amp components, finding the right wire at a decent price proves to be quite an online shopping challenge.
EBRAddict
Is the PTFE for the cool factor? I used a lot of it in a college job building outdoor enclosures where heat tolerance and abrasion resistance were necessary. We went through 100 ft spools frequently. It doesn't hold shape very well, but it is nice and shiny.
Quote from: jball85 on April 24, 2016, 07:27:50 PM
This is Teflon/Kapton (registered trade marks that can't be used anymore by others) from the link above. To terminate the shield i just strip the shield, wrap a wire around the shield, solder then snip off the excess shield and heatshrink. I think his is 26awg, outside diameter ~1.5mm.
jball85
#6
Quote from: EBRAddict on April 25, 2016, 09:37:50 PM
Not for the cool factor, but as you mentioned the heat tolerance. I'm thoroughly sick of the jackets on my lead wires heating up and shrinking back, leaving exposed wire. If anyone knows of a better choice in wire that will hold it's shape and has a good heat resistance then let me know.
I should also add that I use a lot of strain relieving (bending at acute angles) in my builds so if PTFE isn't malleable it might not be the best choice for me.
Tuxedo3
Tayda has some really reasonably priced wire if you are going to place an order from there anytime soon. That's where I buy all my components.
