Overdrive for Bass?
Started by aballen, April 01, 2017, 12:54:14 PM
aballen
It all started when I made him an arcadiator.  My bud, who is a real musician, gigs every week, you know, now has the pedal bug.  The arcadiator is a bit over the top for him though, even with the blend mod... I think he may use it to play a Jamariquai song, but thats it.
Anyone know a good bass overdrive?  He does not want a fuzz, or a distortion, he wants OD.  I loaned him a timmy, but he said it was too mild... I heard the klone does not boost the bass well.  I'm kind of in the dark when it comes to bass pedals, cause I don't play bass.  Seems like most pedals need to be modded to work well with bass, but I'm kind if in the dark here and I want to make him something that earns a permanent spot on his board.
Recommendations?
zombie_rock123
DAM Ezikiel is pretty highly regarded for bass
jmkpcbs has a great one, guitarpcb has a great one and the one I use is the byoc bas overdrive.
AntKnee
Ampegulator? Not sure if that is the right name, but may want to check into that.
Quote from: AntKnee on April 01, 2017, 04:34:04 PM
Ginger
brucer
jposega
ROG Ginger for a very mild drive.
Something based on the Barbershop would be perfect.
The Southampton Fifth Gear is awesome... I believe it's based on an old Electra Distortion (or overdrive), which apparently is almost the same thing as the EQD Speaker Cranker.
Aleph Null
I've had good luck using a Red Llama clone for bass (with a couple of value changes). It gets nasty fast, though. The drive knob on a Klone is actually a dual gang pot; one affects the gain, the other blends in the distorted signal. You could use to separate pots for gain and a dry blend. A dry blend is a common approach to preserving the low end.
