Shin-ei echo master modification.
Started by Willybomb, April 14, 2016, 05:57:54 AM
Willybomb
I posted about this unit in another thread regarding 240v through a footswitch...  Anyway, it's finished, with:
- True bypass and effect on/off indication with a 4pdt footswitch.  The unit isn't completely bypassed as the effect out goes directly to the output jack.  As a result, if you kick it while in bypass the "boing" from the spring reverb will sound.  However, this was a compromise with having an on/off LED coming off the footswitch.
- Dedicated power switch (illuminated! Pretty!) and new fuse holder installed.
These photos were taken before I taped off all the exposed 240v contacts... (the original wiring wasn't taped at all..)
Finished unit.
