First 1590A Build: Stomptown Baby Screamer w/ mods
Started by v00d00blues79, March 26, 2016, 05:12:02 PM
v00d00blues79
I just wrapped up my first 1590A build last night, and I'm hooked!  It's a Stomptown Electronics Baby Screamer.  I used the values for the Keeley mod plus to tweak this little guy.  I love it!
I still suck at enclosure finishes, so this little guy is sitting in a unmarked enclosure.  I want to start doing more finishes on enclosures, but I have the hardest time coming up with ideas.
Anyway, here are the obligatory pics:
Thanks!
Andy
gorditas
Tidy! Aren't those Lumberg jacks the best? If they weren't so (relatively) expensive, I'd use them on everything.
v00d00blues79
Thanks!  This is my first time using them.  I did have a problem where the tip connection wasn't bent correctly on one of them and the Jack would go under instead of over.  A little retensioning and all was well.
Oh, and I did use a BB OPA2134 for the op amp as well.  I forgot to list that above.
Nice, love 1590s. And nothing wrong with a plain enclosure, though it is fun to develop a style that you dig too.
Nice job. For the outside, don't overthink it, I usually use the first thing I see that looks cool / funny / neat and just use that.
Stomptown
v00d00blues79
Thanks guys!  Since I build for myself I typically go function over form.  I have a ton of baby boards built up right now.  This was just the first of many wee ones.  I do have to say that the board mounted pots and led made this one a snap to box up.  I'll know I really cut my teeth on 1590A's when I get to the rest that are all off board pots and LEDs.
Thanks,
Andy
v00d00blues79
I was asked in a PM what changes I made to mod this build to the keeley specs.  Here are the values that I changed:
R3 - 510k
R6 - 2k4
R13 - 510k
C3 - 51pF
C4 - 100n
C6 - 180n
The part numbers listed are the ones from the Stomptown build doc.  I did notice a disconnect between the schematic part numbers and the BOM in the build doc, so the numbers listed are from the BOM, not the schematic.
I really like the way this mod sounds.  It adds a level of ballsiness to the circuit, while still being clear and articulate, that I've not heard before.
Thanks,
Andy
v00d00blues79
Thanks!  I've become infatuated with all things mini now.  I have a pickdropper Trem waiting to be wired up and a bunch more I just got the last bit of parts in for.  Pretty soon my whole board will be tiny.
Stomptown
Quote from: v00d00blues79 on April 07, 2016, 03:35:20 PM
Thanks for the heads up!  I'll take a look and get the schematic updated.
v00d00blues79
You're most welcome.  I meant to shoot you a message about it when I found it, but the little bugger was too much fun to play and I forgot.
