1590A Tonebender MK II
Started by Jakes Dad, March 24, 2016, 02:30:18 AM
Jakes Dad
Just finished up Stomptown's excellent Black Magic MK II.  Matched trannies (Q1 hfe 72, L 64; Q2 hfe 89, L 88; Q3 hfe 155, L 99) and most other parts from Small Bear.  Box was finished with some Rustoleum paint/primer combo which dings pretty easily.  What I thought was a grounding issue turned out to be an out put jack issue that disappeared once it was tightened down well.  I opted to install C2 and C4 on the bottom of the board but it was still fairly challenging to get everything in that end of the box.
Here's the face:
And the guts:
Chuck
Good stuff! That's a really nice looking little box of fun :)
I've seen a few amp build docs where they instruct to use a wirewheel around where jacks will be bolted down (on the inside, this is with chassis that are completely powdercoated/painted), to ensure good ground connection.
AntKnee
Looks good. Nice job packing it in there. I hate the rustoleum stuff, never got good results with it.
v00d00blues79
Nice!  I have one of those boards.  I'm waiting on some small parts for it at the moment.
darrenw6000
dan.schumaker
Looks good.  Its a great sounding fuzz.  I have one boxed up in a 1590G to finish up that board.
Jakes Dad
Quote from: alanp on March 24, 2016, 04:00:48 AM
Alan,
I've painted a couple boxes inside and always scrubbed the area inside around the jacks with a sanding stick - little dicey trying to get a wire wheel inside an effect box.  This was different though.  I dropped everything loosely in the box then tried to tighten things up.  The board rests on the output jack just a little so it runs up hill from the pots to the jack.  I tightened the pots down first then tightened the jacks.  For some reason I forgot to use a tool on the output jack so it was just finger tight.  It felt firm but shifted when the cord was inserted making very slight intermittent contact with the bottom of the board. Of course, when you unplug everything and take it back to the bench to see WTF? is going on everything looks fine.
Chuck
rmfroyd
I am constantly forgetting to tighten my jacks down. I just get so damn excited because the project is nearing completion that I forget...
Sent from my SM-G920V using Tapatalk
